pamac-tray is not starting because /usr/bin/pamac-check-updates is missing
$ cat /var/log/pacman.log | grep pamac
[2013-02-24 12:21] upgraded pamac (0.4.0-2 -> 0.4.1-1)
$ yaourt -Qs pamac
addon-testing/pamac 0.4.1-1
A gtk3 frontend for pyalpm
$ pamac-tray
Exception in thread Thread-1:
File "/usr/lib/python3.3/threading.py", line 639, in _bootstrap_inner
self.run()
File "/usr/bin/pamac-tray", line 70, in run
self.task()
File "/usr/bin/pamac-tray", line 75, in task
call(['/usr/bin/pamac-check-updates'])
File "/usr/lib/python3.3/subprocess.py", line 521, in call
with Popen(*popenargs, **kwargs) as p:
File "/usr/lib/python3.3/subprocess.py", line 818, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.3/subprocess.py", line 1416, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] Нет такого файла или каталога: '/usr/bin/pamac-check-updates'
pamac.service is starting successfully
фев 24 12:22:19 samsung-n127 dbus-daemon[244]: dbus[244]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.servi
фев 24 12:22:19 samsung-n127 dbus[244]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
фев 24 12:22:19 samsung-n127 systemd[1]: Starting Pamac...
фев 24 12:22:20 samsung-n127 dbus-daemon[244]: dbus[244]: [system] Successfully activated service 'org.manjaro.pamac'
фев 24 12:22:20 samsung-n127 dbus[244]: [system] Successfully activated service 'org.manjaro.pamac'
фев 24 12:22:20 samsung-n127 systemd[1]: Started Pamac.
I tried to create a bug-report, but it was not possible
Query {INSERT INTO `flyspray_tasks` ( task_id, date_opened, last_edited_time, project_id, item_summary, detailed_desc, opened_by, percent_complete, task_type, item_status, product_category, product_version, closedby_version, operating_system, task_severity, task_priority, mark_private, due_date, closure_comment, anon_email ) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?)} with params {81,1361684324,1361684324,1,pamac-tray is not starting because /usr/bin/pamac-check-updates is missing,pamac-tray is not starting because /usr/bin/pamac-check-updates is missing $ cat /var/log/pacman.log | grep pamac [2013-02-24 12:21] upgraded pamac (0.4.0-2 -> 0.4.1-1) $ yaourt -Qs pamac addon-testing/pamac 0.4.1-1 A gtk3 frontend for pyalpm $ pamac-tray Exception in thread Thread-1: Traceback (most recent call last): File "/usr/lib/python3.3/threading.py", line 639, in _bootstrap_inner self.run() File "/usr/bin/pamac-tray", line 70, in run self.task() File "/usr/bin/pamac-tray", line 75, in task call(['/usr/bin/pamac-check-updates']) File "/usr/lib/python3.3/subprocess.py", line 521, in call with Popen(*popenargs, **kwargs) as p: File "/usr/lib/python3.3/subprocess.py", line 818, in __init__ restore_signals, start_new_session) File "/usr/lib/python3.3/subprocess.py", line 1416, in _execute_child raise child_exception_type(errno_num, err_msg) FileNotFoundError: [Errno 2] Нет такого файла или каталога: '/usr/bin/pamac-check-updates' pamac.service is starting successfully фев 24 12:22:19 samsung-n127 dbus-daemon[244]: dbus[244]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.servi фев 24 12:22:19 samsung-n127 dbus[244]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service' фев 24 12:22:19 samsung-n127 systemd[1]: Starting Pamac... фев 24 12:22:20 samsung-n127 dbus-daemon[244]: dbus[244]: [system] Successfully activated service 'org.manjaro.pamac' фев 24 12:22:20 samsung-n127 dbus[244]: [system] Successfully activated service 'org.manjaro.pamac' фев 24 12:22:20 samsung-n127 systemd[1]: Started Pamac.,51,0,1,1,13,12,0,3,4,2,0,0,,} Failed! (Incorrect string value: '\xD0\x9D\xD0\xB5\xD1\x82...' for column 'detailed_desc' at row 1)
