Author Topic: pamac - simple graphical package manager for Manjaro Linux  (Read 89991 times)
0 Members and 3 Guests are viewing this topic.
Offline Gringo Linux
  • Neuling
    • Nalug
Re: pamac - simple pacman gui for Manjaro Linux
« Reply #15 on: 05. December 2012, 22:02:53 »
philm you are big ;) superb work
GNU/Linux ....my Life! My Laptop: HP-DV6 Pavillon, my Distro: Manjaro xfce 0.8.2 x86_64
Offline Yoyo
  • Vollwertiges Mitglied
    • Deb Linux
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: Intel HD Graphics 2500, Nvidia Geforce GO 7300
  • GPU driver: free, non-free
  • Kernel: linux319 (x86_64)
  • Skill: Intermediate
« Reply #16 on: 05. December 2012, 23:03:48 »
Thanks, philm :)
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #17 on: 06. December 2012, 04:27:45 »
 8)
Ho, ho, ho, heute kommt de Nikolaus!
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #18 on: 12. December 2012, 19:24:48 »
pamac 0.1 is online now. You'll find it in our Unstable repos.
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #19 on: 12. December 2012, 20:39:18 »
This is the same as was inside Nikolaus-2012.zip?
Offline Yoyo
    • Deb Linux
  • Branch: Stable
  • Desktop: Xfce
« Reply #20 on: 12. December 2012, 21:09:09 »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #21 on: 12. December 2012, 22:27:08 »
Nikolaus was 0.0.1. This has more features. Automatic db sync got added. Also Guillaume is working on an update tool.
Install it with:
Code: [Select]
sudo pacman -U http://mirrors.mycraft.eu/manjaro/pool/pamac-0.1-1-any.pkg.tar.xz
Offline James T
  • Sr. Mitglied
« Reply #22 on: 13. December 2012, 00:59:57 »
Only just tried it very briefly, but it looks and feels fine.
Just a couple of suggestions -- since Manjaro mainly uses sudo, it would be nice if it could prompt for the user's password (possibly with an option for root).  Also ideally it would allow searching and selection as a regular user and only raise the privileges for actual installation and removal.
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
« Reply #23 on: 13. December 2012, 01:47:14 »
If there's one thing that pamac needs, it's a remove unnecessary packages (deps) button running something like 'pacman -Rs $(pacman -Qtdq)' in the background.
Offline davidnotcoulthard
  • Sr. Mitglied
  • Manipulated image.
« Reply #24 on: 13. December 2012, 03:45:16 »
Try using "gksudo" instead of "gksu".
  • Sr. Mitglied
« Reply #25 on: 13. December 2012, 03:49:23 »
8)
Oh! So you're going to sponsor HRT F1 team?
(Read the sidepods!)
Anyway is Pamac available in testing yet?
EDIT:
resized the picture, it was too big!!
« Last Edit: 13. December 2012, 19:42:29 by Parmaster »
Offline vanlong441
  • Artwork Team
  • Skill: Novice
« Reply #26 on: 13. December 2012, 07:26:53 »
tested and satisfied. Option to install applications from Manjaro Unstable and AUR should be considered.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #27 on: 16. December 2012, 22:20:20 »
pamac 0.1.1 comes with a nice updater ;)
Offline Yoyo
    • Deb Linux
  • Branch: Stable
  • Desktop: Xfce
« Reply #28 on: 16. December 2012, 23:18:56 »
Hi, philm
to install this is correct?
Code: [Select]
sudo pacman -U http://mirrors.mycraft.eu/manjaro/pool/pamac-0.1.1-2-any.pkg.tar.xz
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #29 on: 16. December 2012, 23:26:16 »
would be great if the pamac update fusing with Kalu :) then you have 2 in one :)
Dutch go the dutch site :)
