Author Topic: pamac - simple graphical package manager for Manjaro Linux  (Read 102482 times)
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
Re: pamac - simple pacman gui for Manjaro Linux
« Reply #120 on: 11. February 2013, 11:07:50 »
still does i see when i remove whole Xfce parts from my desktop it will remove Lxdm too, i stopped it ok :)
but it says in menu remove lxdm ,  :o
nevermind :)
further works ok
Dutch go the dutch site :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #121 on: 11. February 2013, 11:23:41 »
personally i like not to much automatic remove things, its hard to be safe on removal ;)
you want removal so make friendly as possibly but personall still you can remove what you dont want...
i have installed Mate, so im bussy on removing gnome dependcies.. i remove mayby some icons of it also.. it remove also whole or part of the Mate-desktop ;)
if i remove Xfce, it removes the Lxdm also, that is not what i want...
think better to have more control in Pamac! if you remove parts..
and if parts needed..., it must give a menu first on my idea :)
like on up text:
Cant resolve depencies remove this depencies? :
you get a list where you can choose it wat would be a gonner..
then on the second part it comes shows a list what will be removed..,
personal needs more control in Pamac :)
dont wanna make you angry about it :), its just my idea... to take more control in it..if you dont read the removal you can do worse,
its not that al users this do on this way remove whole Xfce, but you must see as an option, :)
dont know who others think about it?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #122 on: 11. February 2013, 11:38:58 »
I'm glad to hear that the basics working now. Have to play with it a little more, but I think we are getting there.
Offline ultima
  • Held Mitglied
« Reply #123 on: 17. February 2013, 16:54:49 »
Pamac seems to work flawlessly on 0.8.4 Mate install .
« Last Edit: 18. February 2013, 00:58:55 by altima »
Offline ultima
  • Held Mitglied
« Reply #124 on: 17. February 2013, 20:05:03 »
But have to reboot after installs , is it normal !
Offline ultima
  • Held Mitglied
« Reply #125 on: 18. February 2013, 00:59:37 »
After some reboots , everything goes well now with Pamac .
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #126 on: 18. February 2013, 15:09:57 »
I used pamac for installing some libreoffice packages:
I filled the search textbox with "libreoffice"
I checked (explicit install) libreoffice-fr libreoffice-gnome libreoffice-writer
pamac opened a dialog box (without any cancellation button) and asked for selecting the language pack I already selected!
if I perform the same actions with pacman (sudo pacman -S libreoffice-fr libreoffice-gnome libreoffice-writer), no issue is encountered
Why doing it yourself when manjaro-system can do it for you?
Offline ultima
  • Held Mitglied
« Reply #127 on: 19. February 2013, 02:29:50 »
Pamac will need some tweakings I guess .
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #128 on: 19. February 2013, 10:36:04 »
Sure and it is the reason why I posted my findings
Edit: Oh! I've discovered pamac-tray...
Added in XFCE autorun
Let's logout...
« Last Edit: 19. February 2013, 11:37:58 by tun in a cellar »
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #129 on: 19. February 2013, 11:52:06 »
Can we configure pamac-tray (for exaple: refresh frequency)?
Offline ultima
  • Held Mitglied
« Reply #130 on: 19. February 2013, 11:58:57 »
Let's logout...
Ah , I did it that way , but their are other ways to do it , I m not good enough with commands in order to fix it .
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #131 on: 19. February 2013, 12:18:31 »
The current pamac-tray is a very first implementation and is more an example than a real app.
For now it only check updates when the app is launched so it's not very useful. That's why it was not annouced.
Developpement in progress..
Offline ultima
  • Held Mitglied
« Reply #132 on: 19. February 2013, 12:23:09 »
Good news , don t remember who , but we can do Pamac with Terminal Commands , it would be good in order to have some tutorials on this .
You re getting there by the way . Keep it on .
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #133 on: 19. February 2013, 13:06:32 »
Pamac is only a gui, in a terminal use pacman.
Offline ultima
  • Held Mitglied
« Reply #134 on: 19. February 2013, 13:14:15 »
Ok , but how come thiese work from Terminal :
pamac-manager
pamac-tray
pamac-updater
Might not be as Pacman commands but it works .
