Author Topic: pamac - simple graphical package manager for Manjaro Linux  (Read 105158 times)
Offline ultima
  • Held Mitglied
Re: pamac - simple pacman gui for Manjaro Linux
« Reply #105 on: 02. February 2013, 14:55:07 »
I removed it true pamac itself , I don t have the exact  output at all of the terminal per see , but it was removed .
Where it wasd written not to remove Pacman , never saw it .
It might be obveous to some but not to others that aren t computer wiz kids .
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #106 on: 02. February 2013, 15:08:22 »
yeah, but if you in debian remove APT , then you have also an problem , its the same... only i know ubuntu an mint has forked it... for use of there software manager or was it gdebi?  nevermind...
its not only pacman, :)
Dutch go the dutch site :)
Offline ultima
  • Held Mitglied
« Reply #107 on: 02. February 2013, 15:39:31 »
Lesson learned .
Offline tq
  • Neuling
« Reply #108 on: 02. February 2013, 20:11:36 »
Sorry, replied to wrong thread  :P
« Last Edit: 02. February 2013, 20:15:24 by tq »
Offline ultima
  • Held Mitglied
« Reply #109 on: 02. February 2013, 20:14:01 »
Thanx for the comeback tq , appreciated .
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #110 on: 02. February 2013, 23:37:34 »
is this an issue?
i know both use Pyalmp .. i load first add/remove software, then i thought look at te updates..
then switch te update window off...
then is pamac also stopped :) its really not an issue when you know it, i only report, could be stupid... but if that is normal then is ok, it dont gave an error or something :)
only the functions are also Lame.. doesnt quit then :)
« Last Edit: 02. February 2013, 23:39:41 by ringo32 »
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #111 on: 03. February 2013, 12:00:39 »
strange yesterday i find out when double, so use the updater and pamac it self, and close the update then add/remove will shutdown also it dont work, yesterday it had hanging..
day after so try to install someting from the repos... i get this, i quit and log in again , it does again :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #112 on: 03. February 2013, 12:48:57 »
sorry my repository wasnt right ..sorry :)
mirror setting  ;D
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #113 on: 06. February 2013, 22:15:23 »
hmm.. the pamac-updater dont update :) or im i wrong?? i did see the update i missed always, but try to install it doesnt do...did it with kalu :)
but didnt start when try to update..
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #114 on: 07. February 2013, 07:45:18 »
Confirmed here!
A workaround: launch pamac-installer which checks for update and install them!
Why doing it yourself when manjaro-system can do it for you?
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #115 on: 07. February 2013, 17:11:50 »
will try it again other time :)  first on gui then in terminal..,:)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #116 on: 08. February 2013, 15:48:46 »
something confirmed , pamac-updater doesnt work :) not for me mayby in the next version , i use from unstable directly..
when open pamac it self it ask directly i the next picture, after then go back to updater then show it up..
want to confirm and its said nothing to update :)
in terminal
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #117 on: 10. February 2013, 22:52:48 »
Pamac-0.4.0 is out ! It handles now multiple provides and should handle all conflicts situations.
The backend seems almost stable now.
Offline ultima
  • Held Mitglied
« Reply #118 on: 10. February 2013, 23:44:25 »
Good news guinux .
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #119 on: 11. February 2013, 10:41:40 »
works nice ;)
for upcomming evolution i hope suchs as rankmirror not exacly like that but a menu to choose from country  you living and it will rankmirror to the closes mirror and the fastest mirror as wel :)
and the options like remove db.lck or something how it calls and removing some caches would also fine :) and orphans  if that needed but normal i see in this version doesnt needed :-)
but this pamac runs fine now test te updater of it !!
