Author Topic: Nvidia vs Nouveau  (Read 2715 times)
Offline valtam
  • Neuling
Nvidia vs Nouveau
« on: 26. August 2012, 10:41:02 »
Can you please explain how to remove the Nouveau driver and replace it with the Nvidia driver. I had no option to choose the proprietary driver during installation and was stuck with Nouveau which is giving me terrible FPS in Minecraft. Thank you.
Offline Anja Noir
  • Neuling
Re: Nvidia vs Nouveau
« Reply #1 on: 26. August 2012, 20:26:18 »
I have successfuly used the bottom script listed under "Switching between nvidia and nouveau drivers"
on this page: https://wiki.archlinux.org/index.php/NVIDIA However, it would be a good idea to
give the whole page a once-over.
Just my 2 cents. ;)
Offline valtam
  • Neuling
« Reply #2 on: 27. August 2012, 03:03:47 »
I tried your suggestion, it did not work, all I got was a black screen at login and a flashing cursor.
Offline valtam
  • Neuling
« Reply #3 on: 27. August 2012, 03:30:30 »
I also tried this:
mhwd -r pci video-nouveau
mhwd -i pci video-nvidia
Still no luck. I won't be battling this any longer, one reply to the thread, and the IRC room was empty, bad support for a new distro,  time to go back to the more reliable distros.
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #4 on: 27. August 2012, 11:54:20 »
Considering it's our first public release, it's normal some people have troubles, especially with  proprietary drivers.
To help us to improve Manjaro, give us more details about the errors you have and maybe we can help you.
Offline FaulesArschloch
  • Neuling
  • Branch: sta
  • Desktop: Gnome
  • GPU Card: --------------------------------gtx 280m
  • Skill: Novice
« Reply #5 on: 28. August 2012, 20:26:10 »
well....i'm pretty new to arch as well...in the "details" info it says i dont have a graphic card, says "unknown" ....i tried removing every graphics driver and ended up in a terminal log-in screen....installed only nvidia and the others seem removed (cant remove em with mhwd) ....so im pretty much not sure what is installed :D i have an icore7 820qm and a gtx280m
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #6 on: 29. August 2012, 20:03:42 »
Well it is simple to solve:
Code: [Select]
-a/--auto <usb/pci> <free/nonfree> <classid> auto install configs for classid
For nvidia
Code: [Select]
sudo mhwd -a pci nonfree 0300
For nouveau
Code: [Select]
sudo mhwd -a pci free 0300
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #7 on: 12. September 2012, 21:28:12 »
Code: [Select]
[yfdogan@manjaro ~]$ -a/--auto <usb/pci> <free/nonfree> <classid>auto install configs for classid
bash: beklenmeyen dizgecik `<' yakınında sözdizimi hatası
[yfdogan@manjaro ~]$ su
Parola:
[root@manjaro yfdogan]# -a/--auto <usb/pci> <free/nonfree> <classid>auto install configs for classid
meaning 'syntax error', is this code correct?  I can not change the driver.
Code: [Select]
[root@manjaro yfdogan]# mhwd -a pci nonfree 0300> Using config 'video-hybrid-intel-nvidia-bumblebee' for device: 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation
> Using config 'video-hybrid-intel-nvidia-bumblebee' for device: 0000:01:00.0 (0300:10de:0df5) Display controller nVidia Corporation
Error: config 'video-hybrid-intel-nvidia-bumblebee' conflicts with config(s): video-hybrid-intel-nouveau-bumblebee
[root@manjaro yfdogan]# mhwd -a pci free 0300> Skipping already installed config 'video-hybrid-intel-nouveau-bumblebee' for device: 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation
> Skipping already installed config 'video-hybrid-intel-nouveau-bumblebee' for device: 0000:01:00.0 (0300:10de:0df5) Display controller nVidia Corporation
« Last Edit: 12. September 2012, 21:38:35 by YFDogan »
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
