Author Topic: How to disable the window transition fade effect in Openbox?  (Read 1743 times)
Offline wulftone
  • Neuling
  • Branch: stable
  • Desktop: openbox
  • GPU Card: Intel HD4400
  • Kernel: 3.10.22
  • Skill: Intermediate
I don't know when it happened, but recently my windows started doing a fading transition when I alt+tab or switch desktops... I'm not sure how to disable this because I don't see any config in openbox for this.  I'm assuming some update set some new default option... Anyone know how to get rid of it?
Thanks!
Offline LizziAS
  • Vollwertiges Mitglied
  • Branch: Hyssop
  • Desktop: OB-OpenRC
  • GPU Card: 6520G
  • GPU driver: Catalyst
  • Kernel: Zen
Re: How to disable the window transition fade effect in Openbox?
« Reply #1 on: 21. March 2016, 15:55:01 »
i'm assuming you are using compton?  try comton-conf from the aur to edit compton effects.
I'm not aware of any fade effects available in ob by default.  Did you install compiz with openbox somehow?
Offline wulftone
  • Neuling
  • Branch: stable
  • Desktop: openbox
  • Kernel: 3.10.22
« Reply #2 on: 03. April 2016, 20:15:40 »
Ahh thanks for the tip.  It's been so long I'd forgotten about compton.  It seems they added some new defaults.  My ~/.config/autostart had compton -CGb in it.  I checked out compton -h and found the --no-fading-openclose switch.  It must be new in compton.  Works like a charm.  Thanks!  I never would have figured this out without your clue.
Offline merlin
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: custom openbox (built from net)
  • GPU Card: nvidia gtx660
  • GPU driver: nonfree
  • Kernel: linux44_x64
  • Skill: Novice
« Reply #3 on: 04. May 2016, 21:08:04 »
Curiosity has me. While we wait for a torch-bearer, lets discuss a little more.
What are others looking for in an openbox version?
To me, I feel Openbox should be similar to Net but with desktop. I just think Openbox people wany to customize a lot, but don't like the bloat of other flavours.
But I'm only speculating.
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #4 on: 04. May 2016, 21:16:47 »
Openbox with effects is defeating the object, I see the point of compton -C  if their are tearing issues apart from that no point.
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #5 on: 05. May 2016, 05:22:31 »
Truly, Mandog has it right.  Openbox is a minimal windowmanager.  Deliver a minimal desktop with no bells or whistles and those who want to add them can.  Just make sure usb drives automount when inserted and that there is a menu that has the basics installed for manjaro.  No tint2 no compton no plank no conky no thing but a wallpaper with the manjaro logo on it.
Offline merlin
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Skill: Novice
« Reply #6 on: 05. May 2016, 06:59:01 »
shhhh...dont mention wallpaper around mandog :P
