Author Topic: Steam and 32bit Flash  (Read 533 times)
Offline siralucard
  • Neuling
  • Branch: stable (openrc)
  • Desktop: i3
  • GPU driver: free
  • Kernel: linux42-x64
  • Skill: Intermediate
« on: 23. May 2013, 04:54:21 »
This is from a fresh install of the main Xfce edition - version 0.8.5.2-x86_64
Steam became unresponsive when viewing certain games in the store. In particular, it's the games with video trailers that cause the hang up. I did a quick Google search and discovered that I just needed to install the 32bit flash plugin. So if you're dealing with the same problem...close Steam, open a terminal and...
Code: [Select]
sudo pacman -S lib32-flashplugin
Or you could just search for the package with pamac-manager.  That should do the trick.
