Author Topic: Update impossible  (Read 959 times)
Offline phcook
  • Neuling
Update impossible
« on: 21. September 2012, 14:03:20 »
Hi all
There is 22 updates notified, but they are impossible to install. I get the message "Impossible to get an exclusive lock...." although no other instance is open. Rebooting doesn't help..
Any idea?
best regards
phcook
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
Re: Update impossible
« Reply #1 on: 21. September 2012, 14:27:43 »
Back in the day when I used arch deleting the db would help "rm -r /var/lib/pacman/db.lck"
Just backup that file before you delete it.
