Author Topic: Numlockx  (Read 1744 times)
Offline christophe60_fr
  • Neuling
Numlockx
« on: 18. September 2012, 20:12:35 »
Hi everyone,
Does anyone know how to run the automatic activation of the keypad at bootup ?
I use manjaro-xfce-0.8.0-x86_64, numlockx is installed and then ?
I didn't find anything on it (I guess I looked bad...).
Many thanks.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: Numlockx
« Reply #1 on: 18. September 2012, 22:52:40 »
https://wiki.archlinux.org/index.php/Activating_Numlock_on_Bootup
Save the attached txt-file as ~/.config/autostart/Numlockx.desktop
  • Neuling
Re: Numlockx
« Reply #2 on: 20. September 2012, 19:41:07 »
Hi philm,
Thank you for the link but I have already had the opportunity to try unsuccessfully.
I mean : 2.2 to 2.7 --> I have no such file and 2.1 (startx) directly leads me to reboot in console mode ((and then I am unable to access the ~ /. xinitrc for remodify).
What do you mean by "Save the attached txt-file as ~/.config/autostart/Numlockx.desktop" ?
Which attached txt-file ?
I said, but it must be, I'm a beginner.
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
Re: Numlockx
« Reply #3 on: 22. September 2012, 21:46:17 »
See the end of philm's post. He attached a file like in a mail...
  • Neuling
Re: Numlockx
« Reply #4 on: 23. September 2012, 13:04:02 »
Okay, well I did not understand at all.
Anyway, I installed lxdm instead of lightdm and now it's all good.
Solved, therefore.
Too bad, I would have liked to know anyway.
  • Neuling
Re: Numlockx
« Reply #5 on: 23. September 2012, 13:24:57 »
Damn, I just saw the famous attached txt-file...
  • Neuling
[Solved]Numlockx
« Reply #6 on: 24. September 2012, 19:27:20 »
Hi everyone,
Many thanks.
« Last Edit: 24. September 2012, 19:30:10 by christophe60_fr »
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
Re: Numlockx
« Reply #7 on: 24. September 2012, 20:05:34 »
1. You can try and enable numlock in your bios settings if supported.
2. If you are using lightdm you can call it from lightdm.conf, http://askubuntu.com/questions/67952/numlockx-no-longer-works-after-upgrade-to-11-10
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
Re: Numlockx
« Reply #8 on: 24. September 2012, 20:13:07 »
I can easily turn on numlock at startup by activating it in the Settings -> Keyboard -> "Start Numlock at startup"
