Author Topic: deluge not working  (Read 2352 times)
Offline Riley88
  • Jr. Mitglied
  • Branch: testing
  • Desktop: Awesome WM
  • GPU Card: Intel HD 3000
  • GPU driver: OpenSource
  • Kernel: 3.9.11-1
  • Skill: Guru
deluge not working
« on: 18. September 2012, 00:26:35 »
hey i just installed deluge and it installed fine and it shows up in my menu but it dosnt do anything when i launch it im not sure if its a broken package or its just me i did install ktorrent and that works fine.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: deluge not working
« Reply #1 on: 18. September 2012, 18:43:38 »
Works just fine here on x64. Post me your output for deluge in a console ...
Offline Riley88
  • Jr. Mitglied
  • Branch: testing
  • Kernel: 3.9.11-1
  • Skill: Guru
« Reply #2 on: 18. September 2012, 19:47:28 »
[riley@archlinux ~]$ deluge
[ERROR   ] 13:46:19 ui:168 No module named gobject
  File "/usr/lib/python2.7/site-packages/deluge/ui/ui.py", line 149, in __init__
    from deluge.ui.gtkui.gtkui import GtkUI
  File "/usr/lib/python2.7/site-packages/deluge/ui/gtkui/__init__.py", line 1, in <module>
    from gtkui import start
  File "/usr/lib/python2.7/site-packages/deluge/ui/gtkui/gtkui.py", line 37, in <module>
    import gobject
ImportError: No module named gobject
[ERROR   ] 13:46:19 ui:169 There was an error whilst launching the request UI: gtk
[ERROR   ] 13:46:19 ui:170 Look at the traceback above for more information.
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #3 on: 18. September 2012, 22:24:08 »
Are you on KDE ? If im right you´re missing GTK-dependencies. I recommend using Qtorrent in that case instead of pulling all those dependencies.
Offline James T
  • Sr. Mitglied
« Reply #4 on: 18. September 2012, 22:31:12 »
Nonetheless, the package should be considered broken. Required dependencies should be specified in the PKGBUILD file. In this case at least python-gtk.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #5 on: 18. September 2012, 22:47:00 »
Arch has it optional ...
Code: [Select]
optdepends=('python-notify: libnotify notifications'
            'pygtk: needed for gtk ui'
            'librsvg: needed for gtk ui'
            'python2-mako: needed for web ui')
Offline Riley88
  • Jr. Mitglied
  • Branch: testing
  • Kernel: 3.9.11-1
  • Skill: Guru
« Reply #6 on: 19. September 2012, 01:05:06 »
no im on xfce64bit version
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #7 on: 19. September 2012, 07:50:27 »
Right, the dependency should be resolved nonetheless. You could install transmission though and wait untill the problem with deluge is sorted out.
Offline shrinivas
  • Neuling
« Reply #8 on: 19. September 2012, 08:49:31 »
I too am running xfce64, deluge works fine here.
Just for info.
Regards
