Author Topic: Post install. Cannot update.  (Read 9720 times)
Offline James T
  • Sr. Mitglied
Re: Post install. Cannot update.
« Reply #30 on: 17. September 2012, 00:46:27 »
Looks good on the US server now :)
Offline JamesBannon
  • Vollwertiges Mitglied
  • Sanity is over-rated
« Reply #31 on: 17. September 2012, 00:58:28 »
Please just wait. I am rebuilding the repo databases just now. BoxIt is already patched. So same problems won't occur again. When I finished you also should wait so the servers can sync everything. This can take up to several hours depending on your server.
No worries. Thanks.
Murphy's law of server mirror updates :)
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #32 on: 17. September 2012, 02:15:30 »
:) done. Hope I fixed it. Can't tell when all servers are up-to-date. Just try it and report back pls!
Roland
Offline flipper T
  • Jr. Mitglied
« Reply #33 on: 17. September 2012, 02:44:39 »
uk mirrors working now.
...and relax.
thx.
If I'm curt with you it's because time is a factor. I think fast, I talk fast and I need you guys to act fast if you wanna get out of this. So, pretty please... with sugar on top. Clean the [censored] car.
Offline JamesBannon
« Reply #34 on: 17. September 2012, 05:29:38 »
I'm still having problems with invalid key signatures.
Code: [Select]
error: xorg-server-common: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is invalid
error: xorg-server: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is invalid
error: lib32-nvidia-utils: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is invalid
error: upower: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is invalid
error: failed to commit transaction (invalid or corrupted package (PGP signature))
I have tried *deleting* the keyring, reinitialising and repopulating with updated keys to no avail.  :'(
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #35 on: 17. September 2012, 08:21:37 »
Could you try pls:
Code: [Select]
sudo pacman-key --refresh-keys
if this doesn't work try:
Code: [Select]
sudo pacman-key --lsign-key 59152F77
sudo pacman-key --lsign-key 11C7F07E
« Last Edit: 17. September 2012, 08:40:23 by roland »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #36 on: 17. September 2012, 08:40:01 »
We readded our keys to our server. You should see some like this now:
Code: [Select]
gpg: key 247B52CC: "Guillaume Benoit (Guinux) <guillaume@manjaro.org>" not changed
gpg: key 11C7F07E: "Philip Müller (Called Little) <philm@manjaro.org>" not changed
gpg: key 59152F77: "Roland Singer (Manjaro Linux) <roland@manjaro.org>" not changed
Offline JamesBannon
« Reply #37 on: 17. September 2012, 11:32:21 »
OK, this is really starting to piss me off! Exactly the same problem. Exactly the same errors with exactly the same keys.
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #38 on: 17. September 2012, 12:02:50 »
What is the output of
Code: [Select]
sudo pacman-key --refresh-keys ?
If you want to update your system you could temporary solve this problem by deactivating the package signature checking in /etc/pacman.conf. You have to change SigLevel = PackageRequired to SigLevel = Never
Roland
Offline JamesBannon
« Reply #39 on: 17. September 2012, 12:17:04 »
Code: [Select]
gpg: refreshing 67 keys from hkp://pool.sks-keyservers.net
gpg: requesting key 77D01FD6 from hkp server pool.sks-keyservers.net
gpg: requesting key 247B52CC from hkp server pool.sks-keyservers.net
gpg: requesting key 11C7F07E from hkp server pool.sks-keyservers.net
gpg: requesting key 59152F77 from hkp server pool.sks-keyservers.net
gpg: requesting key FFF979E7 from hkp server pool.sks-keyservers.net
gpg: requesting key CDFD6BB0 from hkp server pool.sks-keyservers.net
gpg: requesting key 4C7EA887 from hkp server pool.sks-keyservers.net
gpg: requesting key 6AC6A4C2 from hkp server pool.sks-keyservers.net
gpg: requesting key 824B18E8 from hkp server pool.sks-keyservers.net
gpg: requesting key 31496106 from hkp server pool.sks-keyservers.net
gpg: requesting key EAE999BD from hkp server pool.sks-keyservers.net
gpg: requesting key D30DB0AD from hkp server pool.sks-keyservers.net
gpg: requesting key 0F2A092B from hkp server pool.sks-keyservers.net
gpg: requesting key EC133BAD from hkp server pool.sks-keyservers.net
gpg: requesting key 5CF9C8D4 from hkp server pool.sks-keyservers.net
gpg: requesting key 0901C163 from hkp server pool.sks-keyservers.net
gpg: requesting key 00F0D0F0 from hkp server pool.sks-keyservers.net
gpg: requesting key 4CE1C13E from hkp server pool.sks-keyservers.net
gpg: requesting key 487328A9 from hkp server pool.sks-keyservers.net
gpg: requesting key B47A0DAB from hkp server pool.sks-keyservers.net
gpg: requesting key 6521E06D from hkp server pool.sks-keyservers.net
gpg: requesting key 99AD6E84 from hkp server pool.sks-keyservers.net
gpg: requesting key F53A76ED from hkp server pool.sks-keyservers.net
gpg: requesting key B4440678 from hkp server pool.sks-keyservers.net
gpg: requesting key 1985A992 from hkp server pool.sks-keyservers.net
gpg: requesting key F56C0C53 from hkp server pool.sks-keyservers.net
gpg: requesting key 4F010D48 from hkp server pool.sks-keyservers.net
gpg: requesting key 9205AC90 from hkp server pool.sks-keyservers.net
gpg: requesting key A9999C34 from hkp server pool.sks-keyservers.net
gpg: requesting key F04569AE from hkp server pool.sks-keyservers.net
gpg: requesting key 215B37AD from hkp server pool.sks-keyservers.net
gpg: requesting key 4FA415FA from hkp server pool.sks-keyservers.net
gpg: requesting key 615137BC from hkp server pool.sks-keyservers.net
gpg: requesting key 796CA067 from hkp server pool.sks-keyservers.net
gpg: requesting key 3CFD4BB6 from hkp server pool.sks-keyservers.net
gpg: requesting key 7C50773E from hkp server pool.sks-keyservers.net
gpg: requesting key 3B94FA10 from hkp server pool.sks-keyservers.net
gpg: requesting key 013C2580 from hkp server pool.sks-keyservers.net
gpg: requesting key F40D2072 from hkp server pool.sks-keyservers.net
gpg: requesting key 589874AB from hkp server pool.sks-keyservers.net
gpg: requesting key 983D4366 from hkp server pool.sks-keyservers.net
gpg: requesting key D21E1A55 from hkp server pool.sks-keyservers.net
gpg: requesting key BAB142C1 from hkp server pool.sks-keyservers.net
gpg: requesting key D1CEDDAC from hkp server pool.sks-keyservers.net
gpg: requesting key 9326B440 from hkp server pool.sks-keyservers.net
gpg: requesting key DA2EE423 from hkp server pool.sks-keyservers.net
gpg: requesting key 9741E8AC from hkp server pool.sks-keyservers.net
gpg: requesting key E19DAA50 from hkp server pool.sks-keyservers.net
gpg: requesting key 2D1493D2 from hkp server pool.sks-keyservers.net
gpg: requesting key 70E80477 from hkp server pool.sks-keyservers.net
gpg: requesting key 8406FFF3 from hkp server pool.sks-keyservers.net
gpg: requesting key C0711BF1 from hkp server pool.sks-keyservers.net
gpg: requesting key 91B842AE from hkp server pool.sks-keyservers.net
gpg: requesting key 2072D77A from hkp server pool.sks-keyservers.net
gpg: requesting key F27FB7DA from hkp server pool.sks-keyservers.net
gpg: requesting key EA433FC7 from hkp server pool.sks-keyservers.net
gpg: requesting key F1D357C1 from hkp server pool.sks-keyservers.net
gpg: requesting key AB441196 from hkp server pool.sks-keyservers.net
gpg: requesting key E62EB915 from hkp server pool.sks-keyservers.net
gpg: requesting key 0C84C0A5 from hkp server pool.sks-keyservers.net
gpg: requesting key 8E4B1A25 from hkp server pool.sks-keyservers.net
gpg: requesting key 06361833 from hkp server pool.sks-keyservers.net
gpg: requesting key 7EDF681F from hkp server pool.sks-keyservers.net
gpg: requesting key 3C4F88BC from hkp server pool.sks-keyservers.net
gpg: requesting key 295AFBF4 from hkp server pool.sks-keyservers.net
gpg: requesting key 437520BD from hkp server pool.sks-keyservers.net
gpg: requesting key C2E5C0D2 from hkp server pool.sks-keyservers.net
gpgkeys: key DA3D344AAAAEEFED0279A69470726A6577D01FD6 not found on keyserver
gpg: key FFF979E7: "Allan McRae (Arch Linux Master Key) <allan@master-key.archlinux.org>" not changed
gpg: key CDFD6BB0: "Dan McGee (Arch Linux Master Key) <dan@master-key.archlinux.org>" not changed
gpg: key 4C7EA887: "Ionut Biru (Arch Linux Master Key) <ionut@master-key.archlinux.org>" not changed
gpg: key 6AC6A4C2: "Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>" not changed
gpg: key 824B18E8: "Thomas Bächler (Arch Linux Master Key) <thomas@master-key.archlinux.org>" not changed
gpg: key 31496106: "Andrzej Giniewicz (giniu) <gginiu@gmail.com>" not changed
gpg: key EAE999BD: "Allan McRae <me@allanmcrae.com>" not changed
gpg: key D30DB0AD: "Andrea Scarpino (Arch Linux) <andrea@archlinux.org>" not changed
gpg: key 0F2A092B: "Andreas Radke <andyrtr@archlinux.org>" not changed
gpg: key EC133BAD: "Angel Velásquez <angvp@archlinux.org>" not changed
gpg: key 5CF9C8D4: "Alexander Rødseth <rodseth@gmail.com>" not changed
gpg: key 0901C163: "Balló György <ballogyor@gmail.com>" not changed
gpg: key 00F0D0F0: "Gaetan Bisson <gaetan.bisson@normalesup.org>" not changed
gpg: key 4CE1C13E: "Florian Pritz <bluewind@xinu.at>" not changed
gpg: key 487328A9: "Bartlomiej Piotrowski <b@bpiotrowski.pl>" not changed
gpg: key B47A0DAB: "Connor Behan <connor.behan@gmail.com>" not changed
gpg: key 6521E06D: "Christopher Brannon <chris@the-brannons.com>" not changed
gpg: key 99AD6E84: "Gavin Marciniak-Bisesi <Daenyth@gmail.com>" not changed
gpg: key F53A76ED: "Dan McGee <dpmcgee@gmail.com>" not changed
gpg: key B4440678: "Daniel Isenmann <daniel@archlinux.org>" not changed
gpg: key 1985A992: "Dieter Plaetinck <dieter@plaetinck.be>" not changed
gpg: key F56C0C53: "Dave Reisner <d@falconindy.com>" not changed
gpg: key 4F010D48: "Daniel Wallace <danielwallace@gtmanfred.com>" not changed
gpg: key 9205AC90: "Eric Belanger <eric@archlinux.org>" not changed
gpg: key A9999C34: "Evangelos Foutras <evangelos@foutrelis.com>" not changed
gpg: key F04569AE: "Giovanni Scafora <giovanni@archlinux.org>" not changed
gpg: key 215B37AD: "Guillaume ALAUX <guillaume@archlinux.org>" not changed
gpg: key 4FA415FA: "Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>" not changed
gpg: key 615137BC: "Ionut Biru <ibiru@archlinux.org>" not changed
gpg: key 796CA067: "Ike Devolder <ike.devolder@gmail.com>" not changed
gpg: key 3CFD4BB6: "Jonathan Conder <jonno.conder@gmail.com>" not changed
gpg: key 7C50773E: "Jelle van der Waa <jelle@vdwaa.nl>" not changed
gpg: key 3B94FA10: "Jan de Groot <jgc@archlinux.org>" not changed
gpg: key 013C2580: "Jaroslav Lichtblau (trusted user) <dragonlord@aur.archlinux.org>" not changed
gpg: key F40D2072: "Jonathan Steel <mail@jsteel.org>" not changed
gpg: key 589874AB: "Jürgen Hötzel <juergen@hoetzel.info>" not changed
gpg: key 983D4366: "Justin Davis (juster) <jrcd83@gmail.com>" not changed
gpg: key D21E1A55: "Kaiting Chen <kaitocracy@gmail.com>" not changed
gpg: key BAB142C1: "Kyle Keen <keenerd@gmail.com>" not changed
gpg: key D1CEDDAC: "Laurent Carlier <lordheavym@gmail.com>" not changed
gpg: key 9326B440: "Lukas Fleischer <info@cryptocrack.de>" not changed
gpg: key DA2EE423: "Massimiliano Torromeo (Personal non-work identity) <massimiliano.torromeo@gmail.com>" not changed
gpg: key 9741E8AC: "Pierre Schmitz <pierre@archlinux.de>" not changed
gpg: key E19DAA50: "Peter Richard Lewis <pete@muddygoat.org>" not changed
gpg: key 2D1493D2: "Rémy Oudompheng <remy@archlinux.org>" not changed
gpg: key 70E80477: "Роман Кирилич (Roman Kyrylych) <roman@archlinux.org>" not changed
gpg: key 8406FFF3: "Ronald van Haren <ronald@archlinux.org>" not changed
gpg: key C0711BF1: "Rashif Rahman (Ray) <schiv@archlinux.org>" not changed
gpg: key 91B842AE: "Jakob Gruber <jakob.gruber@gmail.com>" not changed
gpg: key 2072D77A: "Seblu <seblu@seblu.net>" not changed
gpg: key F27FB7DA: "speps <speps@aur.archlinux.org>" not changed
gpg: key EA433FC7: "Sergej Pupykin <arch@sergej.pp.ru>" not changed
gpg: key F1D357C1: "Lukas Jirkovsky <l.jirkovsky@gmail.com>" not changed
gpg: key AB441196: "Stéphane Gaudreault <stephane@archlinux.org>" not changed
gpg: key E62EB915: "Sven-Hendrik Haase <sh@lutzhaase.com>" not changed
gpg: key 0C84C0A5: "Thomas Dziedzic <gostrc@gmail.com>" not changed
gpg: key 8E4B1A25: "Thomas Bächler <thomas@archlinux.org>" not changed
gpg: key 06361833: "Tom Gundersen <teg@jklm.no>" not changed
gpg: key 7EDF681F: "Tobias Powalowski <tobias.powalowski@googlemail.com>" not changed
gpg: key 3C4F88BC: "Timothy Redaelli <tredaelli@archlinux.info>" not changed
gpg: key 295AFBF4: "Thorsten Töpper <atsutane@freethoughts.de>" not changed
gpg: key 437520BD: "Vesa Kaihlavirta <vegai@iki.fi>" not changed
gpg: key C2E5C0D2: "Xyne. <xyne@archlinux.ca>" not changed
gpg: Total number processed: 66
gpg:              unchanged: 66
Yeah, I know I can switch the key verification off. I'll do that next if I have to. However, I'd much rather actually solve the problem. I don't think it's anything at my end. I think the packages themselves aren't properly signed.
ETA: Now I'm off to re-install the system. See you on the flip side.
« Last Edit: 17. September 2012, 12:19:12 by JamesBannon »
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #40 on: 17. September 2012, 12:19:32 »
Hmm, seams ok. I'll check the packages and report to you back.
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #41 on: 17. September 2012, 14:47:14 »
K, problems are found. This was a problem in BoxIt which is solved now but we have fix all corrupted signatures.... working on it...
Offline Roland
  • Administrator
    • Manjaro Linux
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #43 on: 17. September 2012, 17:49:25 »
Currently we uploaded all broken pkgs we found on our main-server. Next step is to rebuild all databases. If that is done it depends how long it takes for our mirrors to sync. Since all your systems should work be a little patience and try later to update your system.
Offline JamesBannon
« Reply #44 on: 17. September 2012, 18:06:18 »
Thank you!  8) I'm glad it's not me. I was beginning to think I'd gone mad or something  :P
