Author Topic: Post install. Cannot update.  (Read 9690 times)
Offline Roland
  • Administrator
    • Manjaro Linux
Re: Post install. Cannot update.
« Reply #15 on: 16. September 2012, 21:39:24 »
Could be a wrong entry in our repository database file. I will check that and inform you. Would be great if you could test it again then.
We had big changed in our repository due to the BoxIt 2.0 update. Sorry for that problem!
Roland
« Last Edit: 16. September 2012, 21:40:56 by roland »
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #16 on: 16. September 2012, 21:45:41 »
Hi Roland.
Nevbies in Tırkey have the same problem too with updating.
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline aeonflux
  • Neuling
« Reply #17 on: 16. September 2012, 21:50:44 »
@verityproductions
Could you test it again ?
Update the repos first.
Ty.
Offline James T
  • Sr. Mitglied
« Reply #18 on: 16. September 2012, 22:22:04 »
Not identical but probably related:
Code: [Select]
:: Retrieving packages from basis...
 filesystem-2012.8-1-any          4.3 KiB  1526K/s 00:00 [##############################] 100%
(5/5) checking package integrity                         [##############################] 100%
error: filesystem: signature from "Roland Singer (Manjaro Linux) <roland@manjaro.org>" is invalid
error: failed to commit transaction (invalid or corrupted package)
This was as of a few moments ago. (The US mirror is at the top of my mirrorlist).
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #19 on: 16. September 2012, 23:08:08 »
@YFDogan: K thx for reporting. Will see what I can do...
@James T: Please try this:
Code: [Select]
sudo pacman -Sy manjaro-keyring
pacman-key --init
pacman-key --populate archlinux
pacman-key --populate manjaro
and please post the whole output :)
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #20 on: 16. September 2012, 23:14:52 »
Code: [Select]
pacman-key --init
After this commands :
Code: [Select]
[yfdogan@manjaro ~]$ sudo pacman -Syyu
:: Paket veritabanları senkronize ediliyor...
 basis                                62,8 KiB   200K/s 00:00 [#################sudo pacman -Sy manjaro-keyring
pacman-key --init
pacman-key --populate manjaro#################] 100%
 platform                             97,9 KiB   260K/s 00:00 [##################################] 100%
 addon                                24,0 KiB   139K/s 00:00 [##################################] 100%
 extra                              1402,9 KiB   377K/s 00:04 [##################################] 100%
 community                          1727,1 KiB   362K/s 00:05 [##################################] 100%
 archlinuxfr                          31,4 KiB   257K/s 00:00 [##################################] 100%
 basis-multilib                        3,1 KiB  31,8K/s 00:00 [##################################] 100%
 multilib                             89,9 KiB   242K/s 00:00 [##################################] 100%
:: Sistem güncellemesi başlatılıyor...
paket bağımlılıkları çözümleniyor...
varsa paketler arası çakışmalara bakılıyor...
Hedefler (1): linux34-3.4.11-1
Toplam İndirme Boyutu:    40,75 MiB
Toplam Kaplayacağı Alan:   57,88 MiB
Net Güncelleme Boyutu:       0,01 MiB
Kuruluma onay veriyor musunuz? [E/h] e
After this update, will bumblebee breake ?
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #21 on: 16. September 2012, 23:19:01 »
No it shouldn't break. Thought it doesn't work anyway on your system. Will help you there later. Have to fix the repo issues first...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #22 on: 16. September 2012, 23:22:28 »
Will be appreciated if I can use this laptop with Manjaro. :)
Code: [Select]
  -> Running build hook: [usbinput]
  -> Running build hook: [fsck]
  -> Running build hook: [plymouth]
==> Creating gzip initcpio image: /boot/initramfs-3.4.11-1-x86_64-manjaro-fallback.img
Generating grub.cfg ...
Found theme: /boot/grub/themes/Archxion/theme.txt
Found linux image: /boot/vmlinuz-3.4.11-1-x86_64-manjaro
Found initrd image: /boot/initramfs-3.4.11-1-x86_64-manjaro.img
  /dev/mapper/control: open failed: Böyle bir aygıt yok
  Failure to communicate with kernel device-mapper driver.
  Check that device-mapper is available in the kernel.
  No volume groups found
Found Windows 8 (loader) on /dev/sda2
done
Is this an error?
« Last Edit: 16. September 2012, 23:25:27 by YFDogan »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #23 on: 16. September 2012, 23:42:04 »
Code: [Select]
That is no error. device-mapper is used for lvm. Just a notice which happen on all normal systems. More info here:
LVM (Logical Volume Management) makes use of the device-mapper feature of the Linux kernel to provide a system of partitions that is independent of the underlying disk's layout. With LVM you can abstract your storage space and have "virtual partitions" which makes it easier to extend and shrink partitions (subject to the filesystem you use allowing this) and add/remove partitions without worrying about whether you have enough contiguous space on a particular disk, without getting caught up in the problems of fdisking a disk that is in use (and wondering whether the kernel is using the old or new partition table) and without having to move other partition out of the way. This is strictly an ease-of-management issue: it does not provide any addition security. However, it sits nicely with the other two technologies we are using.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #24 on: 16. September 2012, 23:44:20 »
About the issues with "corupt" packages. We updated our server-structure and forgot to add one feature. It wasn't a problem before since only I updated all packages. Since Roland and Guillaume are also active now we had some collisions. Those issues should be fixed soon. Just wait for the update ...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #25 on: 16. September 2012, 23:45:37 »
Thanks Rolan and Philm.
Now I m waiting for the solution of Bumblebee. Wish, fix this as soon as possible.
Offline flipper T
  • Jr. Mitglied
« Reply #26 on: 17. September 2012, 00:12:07 »
hi, trying to update
Code: [Select]
jk@manjaro ~]$ packer -Syu
 basis is up to date
 platform is up to date
error: failed retrieving file 'addon.db' from repo.manjaro.org.uk : The requested URL returned error: 403 Forbidden
 addon is up to date
 extra is up to date
 community is up to date
 basis-multilib is up to date
 there is nothing to do
:: Synchronizing aur database...
 aur                                        20  20 [######################]100%
:: Starting full aur upgrade...
 local database is up to date
anything to worry about ?
If I'm curt with you it's because time is a factor. I think fast, I talk fast and I need you guys to act fast if you wanna get out of this. So, pretty please... with sugar on top. Clean the [censored] car.
Offline James T
  • Sr. Mitglied
« Reply #27 on: 17. September 2012, 00:12:28 »
Here is the output (I chopped some of the Arch confirmations):
Code: [Select]
[james@manjaro misc]$ sudo pacman -Sy manjaro-keyring
Password:
Sorry, try again.
Password:
:: Synchronising package databases...
 basis is up to date
error: failed retrieving file 'addon.db' from mirror.dacentec.com : The requested URL returned error: 404 Not Found
 addon is up to date
 extra is up to date
warning: manjaro-keyring-20120504-1 is up to date -- reinstalling
resolving dependencies...
looking for inter-conflicts...
Targets (1): manjaro-keyring-20120504-1
Total Download Size:    0.01 MiB
Total Installed Size:   0.01 MiB
Net Upgrade Size:       0.00 MiB
Proceed with installation? [Y/n] y
 manjaro-keyring-20120504-...     5.7 KiB  2.41M/s 00:00 [##############################] 100%
(1/1) checking package integrity                         [##############################] 100%
(1/1) loading package files                              [##############################] 100%
(1/1) checking for file conflicts                        [##############################] 100%
(1/1) checking available disk space                      [##############################] 100%
(1/1) upgrading manjaro-keyring                          [##############################] 100%
==> Appending keys from manjaro.gpg...
gpg: key 247B52CC: "Guillaume Benoit (Guinux) <guillaume@manjaro.org>" not changed
gpg: key 11C7F07E: "Philip Müller (Called Little) <philm@manjaro.org>" not changed
gpg: key 59152F77: "Roland Singer (Manjaro Linux) <roland@manjaro.org>" not changed
gpg: Total number processed: 3
gpg:              unchanged: 3
==> Locally signing trusted keys in keyring...
  -> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
pub  2048R/247B52CC  created: 2012-05-04  expires: 2022-05-02  usage: SC
                     trust: marginal      validity: full
sub  2048R/72CD35DE  created: 2012-05-04  expires: 2022-05-02  usage: E
[  full  ] (1). Guillaume Benoit (Guinux) <guillaume@manjaro.org>
"Guillaume Benoit (Guinux) <guillaume@manjaro.org>" was already locally signed by key 32B8A9CF
Nothing to sign with key 32B8A9CF
Key not changed so no update needed.
  -> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
pub  4096R/59152F77  created: 2012-05-09  expires: never       usage: SC
sub  4096R/67F91B40  created: 2012-05-09  expires: never       usage: E
[  full  ] (1). Roland Singer (Manjaro Linux) <roland@manjaro.org>
"Roland Singer (Manjaro Linux) <roland@manjaro.org>" was already locally signed by key 32B8A9CF
  -> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
pub  2048R/11C7F07E  created: 2012-05-05  expires: never       usage: SC
sub  2048R/0576724A  created: 2012-05-05  expires: never       usage: E
[  full  ] (1). Philip Müller (Called Little) <philm@manjaro.org>
"Philip Müller (Called Little) <philm@manjaro.org>" was already locally signed by key 32B8A9CF
==> Importing owner trust values...
==> Updating trust database...
gpg: next trustdb check due at 2013-01-22
[james@manjaro misc]$ sudo pacman-key --init
[james@manjaro misc]$ sudo pacman-key --populate archlinux
==> Appending keys from archlinux.gpg...
gpg: key FFF979E7: "Allan McRae (Arch Linux Master Key) <allan@master-key.archlinux.org>" not changed
gpg: key CDFD6BB0: "Dan McGee (Arch Linux Master Key) <dan@master-key.archlinux.org>" not changed
gpg: key 4C7EA887: "Ionut Biru (Arch Linux Master Key) <ionut@master-key.archlinux.org>" not changed
ned by key 32B8A9CF
[james@manjaro misc]$ sudo pacman-key --populate manjaro
gpg:              unchanged: 3
And I still get an error with filesystem reporting as corrupt. Is it possible that updates haven't yet percolated through to all the mirrors?
Offline JamesBannon
  • Vollwertiges Mitglied
  • Sanity is over-rated
« Reply #28 on: 17. September 2012, 00:34:16 »
Still having problems here too. It looks as if the update push has borked somewhere. xorg-server-common causing the problem?
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #29 on: 17. September 2012, 00:36:32 »
Please just wait. I am rebuilding the repo databases just now. BoxIt is already patched. So same problems won't occur again. When I finished you also should wait so the servers can sync everything. This can take up to several hours depending on your server.
