Author Topic: Post install. Cannot update.  (Read 9720 times)
Offline aeonflux
  • Neuling
« on: 16. September 2012, 18:12:34 »
Hey!
Just installed the XFCE version. I am not able to update it through 'pacman'.
I've enabled all the mirrors, but still not working.
I've also tried ignoring the package that's causing the trouble, but it does not work.
Code: [Select]
sudo pacman -Syu
Password:
 basis is up to date
 platform is up to date
 addon is up to date
 extra is up to date
 community is up to date
 basis-multilib is up to date
resolving dependencies...
looking for inter-conflicts...
Targets (22): filesystem-2012.8-1  flashplugin-11.2.202.238-1
              lib32-catalyst-utils-12.8-2  libsystemd-189-2  lightdm-1.3.3-1
              linux-2012.09-1  linux34-3.4.10-1  manjaro-release-0.8.1-1
              mhwd-db-0.1.7-3  mhwd-nvidia-304.43-1
              pacman-mirrorlist-20120911-1  plymouth-0.8.6.1-3  systemd-189-2
              systemd-manjaro-units-20120704-4  systemd-sysvcompat-189-2
              systemd-tools-189-2  thunderbird-15.0.1-1
              thunderbird-i18n-de-15.0.1-1  thunderbird-i18n-fr-15.0.1-1
              upower-0.9.18-2  xorg-server-1.12.4-1
              xorg-server-common-1.12.4-1
Total Download Size:    0.02 MiB
Total Installed Size:   227.29 MiB
Net Upgrade Size:       1.40 MiB
Proceed with installation? [Y/n] y
:: Retrieving packages from extra...
error: failed retrieving file 'xorg-server-common-1.12.4-1-x86_64.pkg.tar.xz' from mirrors.mycraft.eu : Maximum file size exceeded
error: failed retrieving file 'xorg-server-common-1.12.4-1-x86_64.pkg.tar.xz' from ftp.cc.uoc.gr : The requested URL returned error: 403 Forbidden
error: failed retrieving file 'xorg-server-common-1.12.4-1-x86_64.pkg.tar.xz' from repo.manjaro.org.uk : Maximum file size exceeded
error: failed retrieving file 'xorg-server-common-1.12.4-1-x86_64.pkg.tar.xz' from mirror.dacentec.com : Maximum file size exceeded
warning: failed to retrieve some files from extra
error: failed to commit transaction (download library error)
Help me please!
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
Re: Post install. Cannot update.
« Reply #1 on: 16. September 2012, 19:33:02 »
Check your /etc/pacman.conf and /etc/pacman.d/mirrorlist:
Code: [Select]
[yfdogan@manjaro ~]$ cat /etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
#CacheDir    = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
HoldPkg     = pacman glibc
# If upgrades are available for these packages they will be asked for first
SyncFirst   = pacman
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
#SigLevel = Optional TrustedOnly
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`. To populate the local
# keyring with the keys of all official Manjaro Linux packagers run
# `pacman-key --populate manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[basis]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[platform]
[addon]
[extra]
[community]
 [archlinuxfr]
 # The French Arch Linux communities packages.
 Server = http://repo.archlinux.fr/x86_64
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[basis-multilib]
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Code: [Select]
yfdogan@manjaro ~]$ cat /etc/pacman.d/mirrorlist
## Manjaro Linux repository mirrorlist
## Generated on 2012-08-15
## Germany
 Server = http://mirrors.mycraft.eu/manjaro/$repo/$arch
## Greece
 Server = http://ftp.cc.uoc.gr/mirrors/linux/manjaro/$repo/$arch
## United Kingdom
 Server = http://repo.manjaro.org.uk/$repo/$arch
## United States
 Server = http://mirror.dacentec.com/manjaro/$repo/$arch
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline aeonflux
  • Neuling
« Reply #2 on: 16. September 2012, 19:40:37 »
Yes, the first one is almost like yours minus the archlinuxfr thing.
The 2nd one is more up to date.
Just reinstalled it without the nonfree drivers, can't update!
Offline aeonflux
  • Neuling
« Reply #3 on: 16. September 2012, 20:04:26 »
Ok, I tried loads of options but it does not work. Starts to piss me off
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #4 on: 16. September 2012, 20:22:29 »
Yeah, I've got the same problem.
I can still download software and other packages; just can't update the system due to the same reason as you. Literally didn't have this problem yesterday (I had to re-install).
Offline aeonflux
  • Neuling
« Reply #5 on: 16. September 2012, 20:36:35 »
So, nobody can help us? I really need it, it runs so smooth!!!
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #6 on: 16. September 2012, 20:43:49 »
May be changing the mirror will help. Disable one by one and enable again and try ?!
Offline aeonflux
  • Neuling
« Reply #7 on: 16. September 2012, 20:50:28 »
Doesn't work.
Anyways, goodbye Manjaro. Really nice and light though!
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #8 on: 16. September 2012, 20:56:46 »
Manjaro is just born and is still not the final release friend. Give it a chance and post the errors we have may help this distros development. Anyway, it is surely your choice.
Offline aeonflux
  • Neuling
« Reply #9 on: 16. September 2012, 20:57:52 »
Installing Bridge. If you guys solve this, I'll might use it again!
Peace;)
Offline teo57
  • Neuling
« Reply #10 on: 16. September 2012, 21:17:22 »
Make the mistake by quitting Manjaro ... use Arch and distributions based on ArchLinux but none has Manjaro Xfce speed ... you Bridge? ok go there but you know it's all a Arch finally Manjaro you'll see it's the best :)
Offline aeonflux
  • Neuling
« Reply #11 on: 16. September 2012, 21:20:03 »
How could I use a broken Operating System?
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #12 on: 16. September 2012, 21:22:21 »
It is not broken, it s just growing :)
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #13 on: 16. September 2012, 21:24:41 »
We changed our repos, so it takes a while for all our mirrors to sync.
Sorry!
Could you please try it tomorrow again?
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #14 on: 16. September 2012, 21:25:26 »
Hardly "broken". I suspect it's just a temporary issue with the servers at the moment. Everything else works fine. I'd advise giving it a day or two. Otherwise, if something as small as this puts you off, just wait until you try and use an Arch-derivative that actually uses Arch servers!
Edit: wrote this while the admin posted about the repos - told you so!
Stick with Manjaro - it is a beautiful OS that I suspect will be a force to be reckoned with in the near future. Plus, you can't find a better system to learn about Arch. I know this from personal experience.
« Last Edit: 16. September 2012, 21:28:55 by verityproductions »
