Author Topic: [solved] LibreOffice Spellcheck  (Read 1108 times)
Offline Branta
  • Neuling
« on: 15. September 2012, 14:54:06 »
Manjaro .8 LibreOffice Writer
I installed, 'sudo pacman -S LibreOffice-en-GB' and the menu items and labels are now in English but spellcheck does not work.  When I hit an F7 I get the attached screen.  When I click 'OK' both screens go away so I do not have access the buttons on the screen.
Perhaps I must install a dictionary.  What do I do?
« Last Edit: 18. September 2012, 18:44:39 by philm »
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
Re: LibreOffice Spellcheck
« Reply #1 on: 15. September 2012, 17:26:56 »
One of these may be solve your problem:
Code: [Select]
sudo pacman -S aspell
Code: [Select]
sudo pacman -S aspell-en
Code: [Select]
sudo pacman -S hunspell-en
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline Branta
  • Neuling
SOLVED: LibreOffice Spellcheck
« Reply #2 on: 15. September 2012, 19:13:23 »
Thanks, hunspell-en was the only one that worked.
