Author Topic: yaourt -Syua says "not found in AUR"  (Read 3517 times)
Offline avamk
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Fluxbox
  • GPU Card: AMD R7 265
  • GPU driver: default
  • Kernel: Linux 4.2.3-1 x64
  • Skill: Novice
« on: 03. April 2016, 01:19:15 »
Hello,
I've got jitsi and qownnotes installed via AUR in a fully updated Manjaro. Thanks to this forum, I've been using allservers to keep everything updated.
However, starting several days ago, using either allservers or yaourt to update I get this error:
Quote
==> Downloading jitsi PKGBUILD from AUR...
==> ERROR: jitsi not found in AUR.
==> ERROR: unable to update
==> Downloading qownnotes PKGBUILD from AUR...
==> ERROR: qownnotes not found in AUR.
And here is the full output:
http://pastebin.com/V0NQ9Gap
What am I doing wrong? Thanks in advance for your help.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
Re: yaourt -Syua says "not found in AUR"
« Reply #1 on: 03. April 2016, 02:08:32 »
Your topic--"yaourt -Syua says "not found in AUR" makes no sense. "yaourt -Syua is a command to update installed packages, including those installed from the AUR.
Please tell us what you really mean.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #2 on: 03. April 2016, 02:20:05 »
Try to use yaourt -S <package name> to install those packages. On my end it works:
Code: [Select]
[phil@manjaro manjaro-tools-iso-profiles]$ yaourt -S jitsi
x .SRCINFO
x PKGBUILD
x jitsi.desktop
x jitsi.sh
aurelieng commented on 2016-03-27 07:52
It seems that the PKBUILD needs an update ?
== Making package: jitsi 2.8.5426-2 (Sat Mar 26 10:04:27 CET 2016)
== Checking runtime dependencies...
== Checking buildtime dependencies...
== Removing existing $pkgdir/ directory...
== Entering fakeroot environment...
== Starting package()...
/tmp/packerbuild-1000/jitsi/jitsi/src/jitsi
find: The current directory is included in the PATH environment variable, which is insecure in combination with the -execdir action of find.  Please remove the current directory from your $PATH (that is, remove ".", doubled colons, or leading or trailing colons)
== ERROR: A failure occurred in package().
Aborting..
xdevla commented on 2016-03-29 07:28
Packer is causing troubles not the package.
Did update the license and .SRCINFO
aurelieng commented on 2016-03-29 07:34
Well, I unfortunately have the very same error without packer:
BUILD SUCCESSFUL
Total time: 37 seconds
I'm using:
/usr/bin/makepkg is owned by pacman 5.0.1-2
/usr/bin/find is owned by findutils 4.6.0-1
xdevla commented on 2016-03-29 07:40
Weird, same version and I just rebuild it without any issue.
[xavierd@thinkpad ~/aur/maintained/jitsi]
[] $ makepkg -sf
== Making package: jitsi 2.8.5426-3 (Tue Mar 29 09:36:34 CEST 2016)
== Retrieving sources...
- Found jitsi-src-2.8.5426.zip
- Found jitsi.desktop
- Found jitsi.sh
== Validating source files with sha256sums...
jitsi-src-2.8.5426.zip ... Passed
jitsi.desktop ... Passed
jitsi.sh ... Passed
== Extracting sources...
- Extracting jitsi-src-2.8.5426.zip with bsdtar
== Starting build()...
Picked up _JAVA_OPTIONS: -Dawt.useSystemAAFontSettings=on -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel -Dswing.aatext=true
Buildfile: /home/xavierd/aur/maintained/jitsi/src/jitsi/build.xml
clean-bundle-repositories:
clean-test-reports:
clean-macosx:
clean:
init:
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/classes
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/doc/api
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/macosx
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/linux
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/windows
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/freebsd
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/solaris
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/sc-bundles/os-specific/android
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/test-reports
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/test-reports/html
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/release
[mkdir] Created dir: /home/xavierd/aur/maintained/jitsi/src/jitsi/log
-pre-version:
version:
[javac] Compiling 3 source files to /home/xavierd/aur/maintained/jitsi/src/jitsi/classes
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.6
[javac] 1 warning
[echo] Jitsi version 2.8.build.2.8.5426
compile:
[javac] Compiling 2305 source files to /home/xavierd/aur/maintained/jitsi/src/jitsi/classes
bundles:
package:
make:
rebuild:
[echo] ver=2.8.build.2.8.5426
BUILD SUCCESSFUL
Total time: 26 seconds
== Tidying install...
- Removing empty directories...
- Removing libtool files...
- Purging unwanted files...
- Compressing man and info pages...
== Checking for packaging issue...
== Creating package "jitsi"...
- Generating .PKGINFO file...
- Generating .BUILDINFO file...
- Generating .MTREE file...
- Compressing package...
== Leaving fakeroot environment.
== Finished making: jitsi 2.8.5426-3 (Tue Mar 29 09:37:28 CEST 2016)
aurelieng commented on 2016-03-29 07:44
OK, I reset my PATH to a minimal '/usr/local/bin:/usr/bin', and it now works as expected. The problem is on my side, I'm gonna investigate what's wrong with my setup. Sorry for the warning, and thank you for packaging jitsi :-)
jitsi 2.8.5426-3  (2016-03-29 07:28)
( Unsupported package: Potentially dangerous ! )
==> Edit PKGBUILD ? [Y/n] ("A" to abort)
==> A
==> Aborted...
Offline avamk
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Fluxbox
  • Skill: Novice
« Reply #3 on: 03. April 2016, 02:58:32 »
Thanks for your quick response.
Sorry if I was not clear. Like you suggested, I said in the original post that I was indeed trying to *update* my *already* installed jitsi and qownnotes via the "yaourt -Syua" command (I am not trying to install them for the first time). However, I still get the "not found in AUR" error. The full output from that command is linked in my original post. Hope that clears it up!
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #4 on: 03. April 2016, 03:04:44 »
Make sure your /etc/yaourtrc file is still there and correct.
I've attached mine for you to use or compare yours with.
Offline avamk
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Fluxbox
  • Skill: Novice
« Reply #5 on: 03. April 2016, 03:10:19 »
Thanks for attaching yours. I just checked and mine is identical to yours....
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #6 on: 03. April 2016, 03:14:14 »
Then I have no idea, I just ran yaourt -Syyua and it downloaded the google-chrome PKGBULD and udated it just fine.
Offline crazyg4merz
  • Held Mitglied
  • Experience it, that's the way of learning!!
  • Branch: stable
  • Desktop: Gnome
  • GPU Card: Nvidia GTX 970
  • Kernel: Linux420-x64
  • Skill: Intermediate
« Reply #7 on: 03. April 2016, 04:59:51 »
Try yaourt -S jitsi and post the error here. Seems like something is wrong with the PKGBUILD according to the AUR website:
https://aur.archlinux.org/packages/jitsi/
Offline avamk
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Fluxbox
  • Skill: Novice
« Reply #8 on: 05. April 2016, 15:38:35 »
Thanks just tried that. But the only output from yaourt -S jitsi is:
Quote
Strange... did I do something that messed up yaourt?
Offline crazyg4merz
  • Held Mitglied
  • Branch: stable
  • Desktop: Gnome
« Reply #9 on: 05. April 2016, 17:23:14 »
Thanks just tried that. But the only output from yaourt -S jitsi is:Strange... did I do something that messed up yaourt?
Seems like it. Maybe try deleting the /etc/yaourtrc and reinstall yaourt?
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #10 on: 05. April 2016, 18:48:20 »
What does `yaourt jitsi` return?
I see:
Code: [Select]
$ yaourt jitsi
1 aur/jitsi 2.8.5426-3 [installed] (310) (7.54)
    An audio/video SIP VoIP phone and instant messenger written in Java (formerly SIP-Communicator)
2 aur/jitsi-nightly 2.9.20151031-1 (2) (0.36)
Are you connecting to the correct server?
Code: [Select]
$ host aur.archlinux.org
aur.archlinux.org has address 5.9.250.164
aur.archlinux.org has IPv6 address 2a01:4f8:160:3033::2
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
