Author Topic: Smath  (Read 1477 times)
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • Desktop: Plasma 5, Gnome, Cinnamon, Deepin, Unity,
  • GPU Card: Intel
  • GPU driver: free driver
  • Kernel: linux 4.1
  • Skill: Novice
Smath
« on: 29. March 2016, 12:37:02 »
Smath installed but never start
i have this errors:
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: cHRM chunk does not match sRGB
- [AppDir] HTML Export (1.13.5890.6147)
- [AppDir] Export to image (1.9.5890.6148)
- [AppDir] Picture Region (1.10.5890.6147)
- [AppDir] Plot Region (1.9.5890.6149)
- [AppDir] SMath Studio Files Plugin (1.9.5890.6149)
- [AppDir] Special Functions (1.11.5890.6146)
- [AppDir] Text Region (1.10.5890.6148)
- [AppDir] SMath Viewer Files Plugin (1.1.5890.6150)
- [AppDir] XMCD Files Plugin (1.12.5890.6148)
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
  at System.Drawing.GDIPlus.CheckStatus (Status status) <0x40bab0d0 + 0x0015f> in <filename unknown>:0
  at System.Drawing.Image.get_Width () <0x40bcdd10 + 0x0002b> in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Image:get_Width ()
  at .. (System.Windows.Forms.PaintEventArgs ) <0x40d1c930 + 0x0020b> in <filename unknown>:0
  at .. (System.Windows.Forms.PaintEventArgs ) <0x40d1b090 + 0x00bf3> in <filename unknown>:0
  at .. (System.Windows.Forms.PaintEventArgs ) <0x40d1abb0 + 0x00393> in <filename unknown>:0
  at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message& m) <0x40cef560 + 0x00157> in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) <0x40bbeb00 + 0x001f7> in <filename unknown>:0
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) <0x40bbead0 + 0x00024> in <filename unknown>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) <0x40bbea90 + 0x00036> in <filename unknown>:0
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) <0x40bbd150 + 0x003c0> in <filename unknown>:0
Card: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel Ivybridge Desktop GLX Version: 3.0 Mesa 11.1.2
System:    Host: rydh Kernel: 4.4.6-1-MANJARO x86_64 (64 bit) Desktop: Gnome Distro: ManjaroLinux 15.12 Capella
Machine:   Mobo: ASRock model: H61M-DGS R2.0 Bios: American Megatrends v: P1.10 date: 10/01/2013
CPU:       Dual core Intel Pentium G2020 (-MCP-) speed/max: 1698/2900 MHz
American dream. welcome to Guantánamo civil-isation
we are all different ... this is our common
Offline Strit
  • Maintainer
  • Manjaro Torrent Maintainer
    • Strits.dk
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: GTX 760 OC
  • GPU driver: Non-free nvidia 361
  • Kernel: 4.4.8-1-MANJARO
  • Skill: Intermediate
Re: Smath
« Reply #1 on: 29. March 2016, 13:42:10 »
smath is an AUR package. So you should ask the Maintainer of that package.
https://aur.archlinux.org/packages/smath/
Desktop PC: Manjaro XFCE 15.12 (stable, kernel 4.4)
Private Laptop: Manjaro Strit 16.03 (unstable, kernel 4.6)
Work Laptop: Manjaro Strit 16.03 (stable, kernel 4.4)
Netbook: Arch Linux XFCE/LXqt (i686, kernel 4.0)
