Author Topic: Edit Package Build - ?  (Read 2124 times)
Offline Felemur
  • Neuling
  • Desktop: Xfce & Cinnamon
  • Skill: Novice
« on: 26. March 2016, 16:23:08 »
Sorry if this is a dumb question, but when doing updates from a notification in the Update Manager, the first question I get is asking if I want to Edit the Package Build. I notice Yes is the default, but I'm not sure what it means or what I should choose.
If there is a page someone knows of that explains this, I'd be grateful for pointing me in that direction.
Thank you to the Manjaro developers and testers - your work is appreciated.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
Re: Edit Package Build - ?
« Reply #1 on: 26. March 2016, 16:34:42 »
This is for AUR packages, only. Read the notes, if any, that precedes the edit function. There may be information you need to know about. Sometimes--but rarely--a URL or CPU (i686, x86_64) or similar edit may be needed. Sometimes--again, rarely--the package build/install function is broken, and a poster may give info on how to successfully complete the install.
See my signature for links. :D
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline zebedeeboss
  • Neuling
  • Be Nice or Be Some Where Else
  • Branch: stable Manjaro 2015.12
  • Desktop: xfce 4.12.3
  • GPU Card: NVIDIA GK107 [GeForce GT 640] 2Gb
  • GPU driver: nvidia
  • Kernel: 4.4.5-1-MANJARO x86_64 (64 bit)
  • Skill: Novice
« Reply #2 on: 26. March 2016, 16:36:56 »
Have you got AUR support enabled as I don't get asked that question and it's not enabled in my "Update Manager"
The option is being presented so you can alter anything (if you know what you're doing) - I have no clue so I just press upgrade and trust the clever bods know what they are doing :) So far I have not fallen foul of anything but Like I said my AUR is not enabled.
Doesn't specifically answer your question but might give you an idea as to why it's happening. Hopefully a guru will answer soon.
Desktop: Xfce 4.12.3 Distro: ManjaroLinux 15.12 Capella
Quad core Intel Core i5-2320 CPU (-MCP-) cache: 6144 KB
Samsung Evo 250gb SSD - HDD Total Size: 25Tb
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #3 on: 26. March 2016, 16:52:41 »
Regards
This is right , when you want install a aur pkg you can find it in aur page .. example
https://aur.archlinux.org/packages/inkscape-gtk3-bzr/
at the bottom of page you can see the comment of user , if the pkg is broken and maintainer not correct the pkgbuild you can edit the pkgbuild itself to correct ..
Another case is if you are security paranoic  ::)  you can see the pkgbuild to find the source and other info  :)
In the past this option is disable in pacman and octopi (?) but this solution was bad , the user  could think that : aur is part of Manjaro but aur is not repo Manjaro  ;)
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Felemur
  • Neuling
  • Skill: Novice
« Reply #4 on: 26. March 2016, 22:19:33 »
Thank you for all the replies and help.
I take it then, in most cases, unless I see notes applicable to my situation, to choose No to editing, and continue with the build.
The specific case that this came up was with FreeFileSync, which I did find in the AUR, as it didn't come up in the standard repositories.
c00ter: I knew about the first two links, but the last one I had not seen before, and quite helpful to me as a person who is more used to the Mint (Ubuntu/Debian) commands. Thank you.
« Last Edit: 26. March 2016, 22:24:50 by Felemur »
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #5 on: 27. March 2016, 05:22:10 »
You are very welcome. It was worth-its-weight-in-gold when I moved over from Debian a few years ago. It comes of course, via the ArchWiki, which holds the answer to life, the Universe, and everything. ;)
Have fun!
Regards
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #6 on: 27. March 2016, 14:42:07 »
Actually, no. You shouldn't implicitly trust any package on the AUR, and so should read the PKGBUILD and Install files to make sure they won't trash your system.
In reality few people will do this when using a wrapper like yaourt, but best practice and all that...
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline Felemur
  • Neuling
  • Skill: Novice
« Reply #7 on: 27. March 2016, 18:37:11 »
So choose Yes to the edit, and that will bring up information to read?
Offline scachemaille
  • Held Mitglied
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU Card: nVidia GT 330M
  • GPU driver: Nouveau
  • Kernel: 4.8_x64
  • Skill: Intermediate
« Reply #8 on: 27. March 2016, 18:48:56 »
yes it will show you the content of the PKGBUILD and offer you possibility to modify it before to use it to install the software.
but you can also see the content and all useful information on the AUR page of the package.
the comment of user done on the AUR page are given on screen before or after this question, I'm not sure right now exactly when.
Offline Felemur
  • Neuling
  • Skill: Novice
« Reply #9 on: 27. March 2016, 19:13:38 »
OK, thanks. I really do appreciate all the help.
