Author Topic: [linux43] state of extramodules  (Read 2233 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 13. September 2015, 10:35:18 »
Well, as expected most of the key extra-modules are broken. Following I was able to built:
Code: [Select]
linux43-acpi_call-1.1.0-0.1-i686.pkg.tar.xz
linux43-acpi_call-1.1.0-0.1-i686.pkg.tar.xz.sig
linux43-bbswitch-0.8-0.1-i686.pkg.tar.xz
linux43-bbswitch-0.8-0.1-i686.pkg.tar.xz.sig
linux43-ndiswrapper-1.59-0.1-i686.pkg.tar.xz
linux43-ndiswrapper-1.59-0.1-i686.pkg.tar.xz.sig
linux43-nvidiabl-0.88-0.1-i686.pkg.tar.xz
linux43-nvidiabl-0.88-0.1-i686.pkg.tar.xz.sig
linux43-open-vm-tools-modules-2:2013.09.16-0.1-i686.pkg.tar.xz
linux43-open-vm-tools-modules-2:2013.09.16-0.1-i686.pkg.tar.xz.sig
linux43-r8168-8.040.00-0.1-i686.pkg.tar.xz
linux43-r8168-8.040.00-0.1-i686.pkg.tar.xz.sig
linux43-rt3562sta-2.4.1.1_r2-0.1-i686.pkg.tar.xz
linux43-rt3562sta-2.4.1.1_r2-0.1-i686.pkg.tar.xz.sig
linux43-tp_smapi-0.41-0.1-i686.pkg.tar.xz
linux43-tp_smapi-0.41-0.1-i686.pkg.tar.xz.sig
linux43-vhba-module-20140629-0.1-i686.pkg.tar.xz
linux43-vhba-module-20140629-0.1-i686.pkg.tar.xz.sig
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
Re: [linux43] state of extramodules
« Reply #1 on: 13. September 2015, 10:42:26 »
catalyst
Code: [Select]
build_mod/firegl_public.c: In function 'firegl_major_proc_read':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/catalyst/src/fglrx-15.20.1046/archive_files/common/lib/modules/fglrx/build_mod/firegl_public.c:630:9: error: void value not ignored as it ought to be
     len = seq_printf(m, "%d\n", major);
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/catalyst/src/fglrx-15.20.1046/archive_files/common/lib/modules/fglrx/build_mod/firegl_public.o' failed
make[1]: *** [/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/catalyst/src/fglrx-15.20.1046/archive_files/common/lib/modules/fglrx/build_mod/firegl_public.o] Error 1
make[1]: *** Waiting for unfinished jobs....
nvidia
Code: [Select]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c:363:12: error: void value not ignored as it ought to be
     return seq_printf(s, "Binary: \"%s\"\n", registry_keys);
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c: In function 'nv_procfs_read_text_file':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c:563:12: error: void value not ignored as it ought to be
     return seq_puts(s, s->private);
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c:564:1: warning: control reaches end of non-void function [-Wreturn-type]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c: In function 'nv_procfs_read_registry':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.c:364:1: warning: control reaches end of non-void function [-Wreturn-type]
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.o' failed
make[2]: *** [/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia/src/NVIDIA-Linux-x86-355.11/kernel/nvidia/nv-procfs.o] Error 1
nvidia-304
Code: [Select]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c:610:12: error: void value not ignored as it ought to be
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c: In function 'nv_procfs_read_text_file':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c:677:12: error: void value not ignored as it ought to be
  cc -Wp,-MD,/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/.nv-vm.o.d  -nostdinc -isystem /usr/lib/gcc/i686-pc-linux-gnu/5.2.0/include -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m32 -msoft-float -mregparm=3 -freg-struct-return -fno-pic -mpreferred-stack-boundary=2 -march=i686 -mtune=generic -maccumulate-outgoing-args -Wa,-mtune=generic32 -ffreestanding -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -I/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"304.128\" -Wno-unused-function -Wuninitialized -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vm)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/.tmp_nv-vm.o /home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-vm.c
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c:678:1: warning: control reaches end of non-void function [-Wreturn-type]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c: In function 'nv_procfs_read_registry':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.c:611:1: warning: control reaches end of non-void function [-Wreturn-type]
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.o' failed
make[3]: *** [/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-304xx/src/NVIDIA-Linux-x86-304.128/kernel/nv-procfs.o] Error 1
nvidia-340
Code: [Select]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c:359:12: error: void value not ignored as it ought to be
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c: In function 'nv_procfs_read_text_file':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c:555:12: error: void value not ignored as it ought to be
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c:556:1: warning: control reaches end of non-void function [-Wreturn-type]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c: In function 'nv_procfs_read_registry':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.c:360:1: warning: control reaches end of non-void function [-Wreturn-type]
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.o' failed
make[2]: *** [/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/nvidia-340xx/src/NVIDIA-Linux-x86-340.93/kernel/nv-procfs.o] Error 1
make[2]: *** Waiting for unfinished jobs....
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #2 on: 13. September 2015, 11:16:36 »
Nvidia got simply fixed with:
Code: [Select]
--- a/kernel/nv-procfs.c
+++ b/kernel/nv-procfs.c
@@ -360,7 +360,8 @@ nv_procfs_read_registry(
     registry_keys = ((nvl != NULL) ?
             nvl->registry_keys : nv_registry_keys);
-    return seq_printf(s, "Binary: \"%s\"\n", registry_keys);
+    seq_printf(s, "Binary: \"%s\"\n", registry_keys);
+    return 0;
 static ssize_t
@@ -560,7 +561,8 @@ nv_procfs_read_text_file(
     void *v
-    return seq_puts(s, s->private);
+    seq_puts(s, s->private);
+    return 0;
catalyst however builds but has the same issues as with linux42
Code: [Select]
--- a/firegl_public.c
+++ b/firegl_public.c
@@ -627,7 +627,8 @@ static int firegl_major_proc_read(struct
     len = snprintf(buf, request, "%d\n", major);
 #else
-    len = seq_printf(m, "%d\n", major);
+    seq_printf(m, "%d\n", major);
+    len = 0;
 #endif
     KCL_DEBUG1(FN_FIREGL_PROC, "return len=%i\n",len);
Offline wolfyrion
  • Sr. Mitglied
  • Branch: UNSTABLE
  • Desktop: PLASMA/KDE
  • GPU Card: ZOTAC AMP EXTREME EDITION 980
  • GPU driver: NON-FREE
  • Kernel: LATEST
  • Skill: Intermediate
« Reply #3 on: 15. September 2015, 09:34:22 »
Tested this morning , dint go quite well :o
Well lets say that keyboard and mouse were not working so I couldnt login to test more stuff....
So I stopped at that point....
Thanks for the new kernel! :)
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
« Reply #4 on: 16. September 2015, 08:46:21 »
'LLo,
I tested it yesterday via msm & it both install 4.2 & 4.3 ?  :o
Otherwise, on my full intel laptop with e19-15.09, all sounds working fine at this moment with 4.3  ;)
"Are you enlightened ?"
Offline kremator
  • Vollwertiges Mitglied
  • meh...
  • Branch: unstable
  • Desktop: KDE5
  • GPU Card: m8600GT
  • GPU driver: Nvidia nonfree
  • Kernel: 4.xx
« Reply #5 on: 18. September 2015, 03:45:33 »
20minutes after the first boot of 4.3 system froze with blinking capslock and scrollock (kernel panic)
Never happened in 4.2 What is the best way to debug it? sudo journalctl shows mostly kde errors
Code: [Select]
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34340, resource id: 16777309, major code: 19 (DeleteProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34353, resource id: 16777309, major code: 19 (DeleteProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34354, resource id: 16777309, major code: 18 (ChangeProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34355, resource id: 16777309, major code: 19 (DeleteProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34356, resource id: 16777309, major code: 19 (DeleteProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34357, resource id: 16777309, major code: 19 (DeleteProperty), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34358, resource id: 16777309, major code: 7 (ReparentWindow), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34359, resource id: 16777309, major code: 6 (ChangeSaveSet), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34360, resource id: 16777309, major code: 2 (ChangeWindowAttributes), minor code: 0
Sep 18 02:08:26 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34361, resource id: 16777309, major code: 10 (UnmapWindow), minor code: 0
Sep 18 02:08:53 kremix-inspiron kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Sep 18 02:08:53 kremix-inspiron pgld[6661]: INFO: Connected to dbus system bus.
Sep 18 02:08:53 kremix-inspiron pgld[6664]: INFO: Started.
Sep 18 02:08:54 kremix-inspiron pgld[6664]: INFO: ASCII: 263321 entries loaded from "/var/lib/pgl/master_blocklist.p2p"
Sep 18 02:08:54 kremix-inspiron pgld[6664]: INFO: Blocking 263321 IP ranges (771373434 IPs).
Sep 18 02:08:54 kremix-inspiron pgld[6664]: INFO: Binding to queue 92
Sep 18 02:08:54 kremix-inspiron pgld[6664]: INFO: ACCEPT mark: 20
Sep 18 02:08:54 kremix-inspiron pgld[6664]: INFO: REJECT mark: 10
Sep 18 02:08:54 kremix-inspiron kernel: Netfilter messages via NETLINK v0.30.
Sep 18 02:08:54 kremix-inspiron sudo[6202]: pam_unix(sudo:session): session closed for user root
Sep 18 02:08:57 kremix-inspiron kdeinit5[652]: networkmanager-qt: void NetworkManager::AccessPointPrivate::propertiesChanged(const QVariantMap&) Unhandled property "LastSeen"
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53002, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53003, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53012, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53013, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53014, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53015, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53016, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53017, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53018, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53019, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53022, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53023, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53024, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53025, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53026, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53027, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53028, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:38 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53029, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57815, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57816, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58158, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58159, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58160, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58161, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58162, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58163, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:41 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58164, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:46 kremix-inspiron kdeinit5[6890]: initialization OK, home trash dir: "/home/kremix/.local/share/Trash"
Sep 18 02:09:46 kremix-inspiron kdeinit5[6890]: listdir:  QUrl("trash:/")
Sep 18 02:09:50 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63610, resource id: 29360129, major code: 18 (ChangeProperty), minor code: 0
Sep 18 02:09:50 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63614, resource id: 29360130, major code: 18 (ChangeProperty), minor code: 0
Sep 18 02:09:51 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 268, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:51 kremix-inspiron kwin_x11[724]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 269, resource id: 0, major code: 14 (GetGeometry), minor code: 0
Sep 18 02:09:52 kremix-inspiron kdeinit5[652]: networkmanager-qt: void NetworkManager::AccessPointPrivate::propertiesChanged(const QVariantMap&) Unhandled property "LastSeen"
Sep 18 02:09:53 kremix-inspiron kdeinit5[652]: networkmanager-qt: void NetworkManager::AccessPointPrivate::propertiesChanged(const QVariantMap&) Unhandled property "LastSeen"
-- Reboot --
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #6 on: 18. September 2015, 08:09:52 »
virtualbox
Code: [Select]
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxdrv/linux/SUPDrv-linux.c: In function 'VBoxDrvLinuxUnload':
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxdrv/linux/SUPDrv-linux.c:488:8: error: void value not ignored as it ought to be
     rc = misc_deregister(&gMiscDeviceUsr);
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxdrv/linux/SUPDrv-linux.c:493:8: error: void value not ignored as it ought to be
     rc = misc_deregister(&gMiscDeviceSys);
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxdrv/linux/SUPDrv-linux.o' failed
/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxnetadp/linux/VBoxNetAdp-linux.c:439:8: error: void value not ignored as it ought to be
     rc = misc_deregister(&g_CtlDev);
scripts/Makefile.build:258: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxnetadp/linux/VBoxNetAdp-linux.o' failed
make[2]: *** [/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxnetadp/linux/VBoxNetAdp-linux.o] Error 1
scripts/Makefile.build:403: recipe for target '/home/phil/dev/git/manjaro/repositories/extra/linux43-extramodules/virtualbox-modules/src/dkms/vboxhost/5.0.4/build/vboxnetadp' failed
Offline kremator
  • meh...
  • Branch: unstable
  • Desktop: KDE5
  • GPU Card: m8600GT
  • Kernel: 4.xx
« Reply #7 on: 19. September 2015, 00:13:01 »
second kernel panic. similar circumstances. peer guardian running in the background. the moment I start qbittorrent: kernel panics. never occurred in 4.2 and lower. since I don't know how to debug it will stop using rc1 and wait for rc2 to come out.
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #8 on: 22. September 2015, 20:30:46 »
4.3 RC1 worked with Nvidia, 4.3 RC2 gave me just a tty
Fixed, thanks
J.
« Last Edit: 22. September 2015, 21:52:28 by Jeannie »
Hitten by the door in the back when I left Manjaro.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #9 on: 23. September 2015, 23:45:09 »
Fine that a RC works for you. I rebuilt all extramodules as the deps went wrong before ;)
