Author Topic: pacman: error while loading shared libraries  (Read 5768 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 04. March 2013, 13:15:57 »
You might get this error:
Quote
pacman: error while loading shared libraries: libarchive.so.12: cannot open shared object file: No such file or directory
Fix it like this:
Code: [Select]
[tux@manjaro pacman]$ ls /usr/lib/libarchive.so*
/usr/lib/libarchive.so     /usr/lib/libarchive.so.13.1.2
[tux@manjaro pacman]$ sudo ln -sfv /usr/lib/libarchive.so.13 /usr/lib/libarchive.so.12
[sudo] password for tux:
‘/usr/lib/libarchive.so.12’ -> ‘/usr/lib/libarchive.so.13’
[tux@manjaro pacman]$ sudo pacman -U *16*x*pkg*xz
loading packages...
resolving dependencies...
looking for inter-conflicts...
Targets (1): pacman-4.0.3-16
Total Installed Size:   3.54 MiB
Net Upgrade Size:       0.00 MiB
Proceed with installation? [Y/n]
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) upgrading pacman                             [######################] 100%
[tux@manjaro pacman]$ sudo rm -v /usr/lib/libarchive.so.12
« Last Edit: 04. March 2013, 16:14:16 by philm »
Offline fredbeer
  • Neuling
Re: pacman: error while loading shared libraries
« Reply #1 on: 05. March 2013, 04:47:42 »
howe do i install it.i get the same message
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #2 on: 05. March 2013, 22:33:20 »
Do the steps I posted starting with [tux@manjaro pacman]$  in a terminal:
Code: [Select]
sudo pacman -Syu
Offline ksose
  • Neuling
  • Skill: Novice
« Reply #3 on: 09. October 2015, 23:18:12 »
hi, i the same problem with libreoffice
when make a CLI
Code: [Select]
$ libreoffice
/usr/lib/libreoffice/program/soffice.bin: error while loading shared libraries: libGLEW.so.1.13: cannot open shared object file: No such file or directory
but i have a different request to lib
my output is
Code: [Select]
ls /usr/lib/libGLEW.so*
/usr/lib/libGLEW.so@  /usr/lib/libGLEW.so.1.12@  /usr/lib/libGLEW.so.1.12.0
edit --------------------------
Ok i solve, but i think not a perfect solution but it wiork
My system search the libGLEW.so.1.13 library
I try rename the library libGLEW.so.1.12 in 13
and......
works!!!
« Last Edit: 11. October 2015, 11:39:38 by ksose »
Semina Linux tanto Windows si pianta da solo!
